Nerox Posted July 25, 2008 Share Posted July 25, 2008 Again I have another, probably, interesting question Can I move every mesh point of an object along its normal? Due to scale without point distance variation. I'm building a Feather system, and I have some colliding issues. So I was thinking to copy the original mesh, scale this down a little, and copy the feathers to it. Having the original mesh serving purely as a visual dummy. But if you scale an object from the center of the object the distance between the new and previous point location may vary. That's not what I want so I hope I'm able to move every point along it normal (in negative) for an X distance. I'm pretty sure I need an point Sop, and some how orientate the point translaten axis to it's normal, but that's where I get stuck. Hope any one can give me a little tip. Quote Link to comment Share on other sites More sharing options...
kumpa Posted July 25, 2008 Share Posted July 25, 2008 Peak SOP Quote Link to comment Share on other sites More sharing options...
Nerox Posted July 25, 2008 Author Share Posted July 25, 2008 Peak SOP Great, thanks! Quote Link to comment Share on other sites More sharing options...
MIguel P Posted July 25, 2008 Share Posted July 25, 2008 Great, thanks! Or if you want more control, like offset only some areas, you can use a Point SOP and write $TX+$NX*... in each position field. Quote Link to comment Share on other sites More sharing options...
Jason Posted July 26, 2008 Share Posted July 26, 2008 Tnx! exactly what I initially was looking for . And a nice addition my current setup.More and more I'm getting familiar with the process of creating/modifing/using of attributes, extremely helpful. I'll never go back to Maya . I used to work for a Autodesk reseller, back then I was totally pro Autodesk due to several brainwash sessions . So from my opinion it's quite a achievement that Houdini totally blow me away and made me willing never to go back. Good to hear it! You could also use a VOP SOP, and inside that use a "Displace Along Normal VOP" and wire up the outputs. VEX/VOPs is a whole new playground for you too then. Take care, Jason Quote Link to comment Share on other sites More sharing options...
Nerox Posted July 26, 2008 Author Share Posted July 26, 2008 Good to hear it!You could also use a VOP SOP, and inside that use a "Displace Along Normal VOP" and wire up the outputs. VEX/VOPs is a whole new playground for you too then. Take care, Jason Indeed, I've ordered the 3dbuzz's Houdini Fasttrack and technical effects Dvd's. They should give me an basic/interm look at Vex, really can't wait. I've tried some minor things using vex but I couldn't get anything usefull out of it, due to my 'unknowingness' of the nodes functions. Time will cover that, I assume. Quote Link to comment Share on other sites More sharing options...
