somajulia Posted July 26, 2008 Share Posted July 26, 2008 Hi guys. I know this is probably very simple but i cant get each butterfly to get a different randomized angle of the wings per copy basis. After i have created the wing i use a transform and use cos to animate a flapping motion at a certain angle, i then mirror this to get the top wings, i do the same to get the bottom wings referencing the animation of the top wings. When i copy it to the particles and try to randomize each different set of wings i only get a randomized angle of the wings but its the same for each copy. They all flap at the same angle. Hope this makes sense and i am sure it is really obvious but please shed the light. Can anyone help please. thank you.. randomize.hipnc Quote Link to comment Share on other sites More sharing options...
eetu Posted July 26, 2008 Share Posted July 26, 2008 You can just stamp the copy number, e.g. variable "copynr", value "$PT". Then in your flapping animation it would be something like cos( $FF * 100 + rand( stamp( "../copy1" , "copynr", 0 ) ) ) (offsetting the angle with a random value seeded with the copy number) eetu. Quote Link to comment Share on other sites More sharing options...
somajulia Posted July 27, 2008 Author Share Posted July 27, 2008 Thanks eetu, It worked a treat, so simple (oopps!), i was referencing things in the wrong order not knowing where to add the "copynr" stamp. Cheers!! Quote Link to comment Share on other sites More sharing options...
