mic Posted August 1, 2008 Share Posted August 1, 2008 hello! i have the strange problem with age attribute of particles. For example, let's create location -> attribute1 ($AGE) -> split1 -> attribute2 ($AGE) (another , because (first strange moment for me) after split operation new particles don't know their age correctly) -> split2 (new) -> attribute2 ($AGE again). Tell me please why some 'age' values are constant all the simulation? Quote Link to comment Share on other sites More sharing options...
SpencerL Posted August 1, 2008 Share Posted August 1, 2008 You dont need to create an Attribute POP in order to access $AGE. Age is already on each particle by default. $AGE's attribute name appears as "life[0]". "life[1]" is $LIFESPAN and $LIFE equals "$AGE/$LIFESPAN". I know that can be confusing. $AGE is in seconds. If you were to use your example, do you have $AGE as the "value" in the Attribute POP? Quote Link to comment Share on other sites More sharing options...
mic Posted August 1, 2008 Author Share Posted August 1, 2008 yes, i know about all these attrs. my problem is to kill splitted particles if they flied not far enough from the parent particle. (kill Rule = [$AGE > 1.5 && $DIST < 1.75], where $DIST = sqrt (pow($TX - poppoint($PT, "ini_pos", 0), 2) + pow(..) + pow(..)) {ini_pos - (attr) birth position of splitted particle}) and there is an option in split op - preserve birth group, if it is on - ini_pos everytime equals position, but $AGE or $LIFE is correct, if it is off - ini_pos is correct but $AGE of splitted particles - not.. I've solved this problem somehow but don't understand the reason of this strange behavior.. Quote Link to comment Share on other sites More sharing options...
SpencerL Posted August 1, 2008 Share Posted August 1, 2008 can you post the scene? Quote Link to comment Share on other sites More sharing options...
mic Posted August 1, 2008 Author Share Posted August 1, 2008 SpencerL said: can you post the scene? ok, let's formalize the problem -> testAge.hip i added age attr - and in detail view you can see that only the second time splitted particles have 'true' age. why so? (forget about all above, i think if i understand this all will be clear.) testAge.hipFetching info... Quote Link to comment Share on other sites More sharing options...
SpencerL Posted August 1, 2008 Share Posted August 1, 2008 mic said: ok, let's formalize the problem -> testAge.hip i added age attr - and in detail view you can see that only the second time splitted particles have 'true' age. why so? (forget about all above, i think if i understand this all will be clear.) hmmm...there is something really flakey going on here. I opened your scene and created a new attribute called "age" and assigned the value "$AGE" to it. Its exaclty as you had it, and it works but your version of the attribute doesnt. Im guessing its a bug. What build are you using? I tested it on 9.1.279 Quote Link to comment Share on other sites More sharing options...
mic Posted August 1, 2008 Author Share Posted August 1, 2008 SpencerL said: hmmm...there is something really flakey going on here. I opened your scene and created a new attribute called "age" and assigned the value "$AGE" to it. Its exaclty as you had it, and it works but your version of the attribute doesnt. Im guessing its a bug. What build are you using?I tested it on 9.1.279 9.1.244 thank you, that's not the only bug this case unfortunately.. Quote Link to comment Share on other sites More sharing options...
