kensonuken Posted August 15, 2008 Share Posted August 15, 2008 I want to archive the ifb files can I do that? like the way its used in Prman ReadArchive "test.rib" just like that is there anyway to read IFB data? Quote Link to comment Share on other sites More sharing options...
edward Posted August 15, 2008 Share Posted August 15, 2008 No, but you can read .bgeo files at render time. 1. Save your geometry as .bgeo 2. Create a Mantra: Delayed Load SHOP. Give it the path to your geometry. 3. Assign the created SHOP to an empty (or proxy) Geometry object under the Render > Geometry > Procedural Shader parameter Quote Link to comment Share on other sites More sharing options...
kensonuken Posted August 23, 2008 Author Share Posted August 23, 2008 i would like to make certain tasks automated but would like to know if i can save a part of render script as .ifd archive? that will be much helpful... Quote Link to comment Share on other sites More sharing options...
Jason Posted August 23, 2008 Share Posted August 23, 2008 i would like to make certain tasks automated but would like to know if i can save a part of render script as .ifd archive? that will be much helpful... You can generate .ifd snippets (see the Mantra Archive ROP- but its not well documented I'm afraid) and you can source them into other IFDs. I think you might need clarification from SESI on this workflow. There used to be a way in 8.x to AutoArchive Geometry out to .bgeos for use with Delayed Reads but currently you might have to do this yourself; perhaps with a Geometry ROP. You can use the ROP dependencies to help with this to some degree. We're still hoping AutoArchiving returns some day, perhaps in a different form... I know I miss it a bit. Quote Link to comment Share on other sites More sharing options...
kensonuken Posted August 30, 2008 Author Share Posted August 30, 2008 but can any big guy up here can recommend Sidefx guys to develop such Archive feature into Mantra.. that will be really helpful... Quote Link to comment Share on other sites More sharing options...
