ygalula Posted August 30, 2008 Share Posted August 30, 2008 Hello, When I try to render a frame range of my animation, I get the attached error... However, when I try to render a still image (from the Right Click to Choose render driver from the left of the viewport), it works... ? Thanks Quote Link to comment Share on other sites More sharing options...
Jason Posted August 30, 2008 Share Posted August 30, 2008 When I try to render a frame range of my animation, I get the attached error... Would it be possible for you to upgrade to the latest 9.5 or even the latest 9.1? That looks like a bug in SOHO and most likely has been fixed in later versions. You seem to be at 9.1.176, correct? DownloadingHoudini Quote Link to comment Share on other sites More sharing options...
ygalula Posted August 31, 2008 Author Share Posted August 31, 2008 Thanks, but I was using 9.5.176 and upgraded to 9.5.213, and it still doesn't work... Quote Link to comment Share on other sites More sharing options...
symek Posted August 31, 2008 Share Posted August 31, 2008 Hello,When I try to render a frame range of my animation, I get the attached error... However, when I try to render a still image (from the Right Click to Choose render driver from the left of the viewport), it works... ? Thanks It looks like something is wrong with your camera. There is a error during camera's matrix computation. Rendering via view port does not use the actual camera and thus can work. Could you attach simplified example of you scene? Maybe you did something special with your cam (like scaled to zero, parent to null, that is scaled etc? ). Quote Link to comment Share on other sites More sharing options...
ygalula Posted August 31, 2008 Author Share Posted August 31, 2008 Thanks, I had a camera going along a curve. I tried creating a new camera, parenting it to the problematic camera and rendering through the new cam. And it worked... Anyway, thanks! Quote Link to comment Share on other sites More sharing options...
