ykcosmo Posted September 23, 2008 Share Posted September 23, 2008 I have a problem on shatter sop and cookie sop. whatever I use shatter or cookie by hand, if the cut times are more than 6, the model will be broken. How do you guys deal with this problem? Thanks for any anwsers. shatter.hip Quote Link to comment Share on other sites More sharing options...
kleer001 Posted September 23, 2008 Share Posted September 23, 2008 (edited) I have no solution at the moment, but in my experience boolian operations are usually unreliable from any package. That said Houdini is usually good with them. What version of Houdini is this for? 9.5? Edited September 23, 2008 by kleer001 Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted September 23, 2008 Author Share Posted September 23, 2008 yes,9.5.230 Quote Link to comment Share on other sites More sharing options...
Jason Posted September 23, 2008 Share Posted September 23, 2008 yes,9.5.230 Sometimes scaling your object up by 10 or 100x can help. You can scale it back down afterward. Quote Link to comment Share on other sites More sharing options...
ykcosmo Posted September 24, 2008 Author Share Posted September 24, 2008 hmm.....sometimes it works with scaling 10X, sometimes doesn't work.....-.-! Is the cookie sop of 9.5 really different from 9.0? Quote Link to comment Share on other sites More sharing options...
curveU Posted September 26, 2008 Share Posted September 26, 2008 How do you guys deal with this problem? Hi, i'm not sure how other people handle this kind of problems. I just try to use some digital asset I found in the forum or Exchange. Kumpa made a fracture tool in this post, which I once used for a small project, and it worked fine to me. It's before H9.5 but you could try it. Hope it helps, Quote Link to comment Share on other sites More sharing options...
kleer001 Posted September 26, 2008 Share Posted September 26, 2008 have you tried scaling 100X ? 1000X ? You could always do 3 cuts, bake, then 3 more. Quote Link to comment Share on other sites More sharing options...
