CeeGee Posted October 2, 2008 Share Posted October 2, 2008 I make deforming gorund, and when i copy box on it, Box rotation i like the point that was copy on it, I whant to achive that but with particle... i post hip file to explain my idea... particle_rotate.hipncFetching info... Thank in advanced Quote Link to comment Share on other sites More sharing options...
Rudinie Posted October 20, 2008 Share Posted October 20, 2008 I kind of had the same question and asked it here (with solution) : http://forums.odforce.net/index.php?showtopic=7975. Quote Link to comment Share on other sites More sharing options...
mangi Posted October 20, 2008 Share Posted October 20, 2008 hi there, I am not to sure what you are looking for in your explanation. Is it that you don't want the cube to rotates? I have window64 bit so I couild not make a quicktime, here are the first animation files okay is this what you mean? mangi Quote Link to comment Share on other sites More sharing options...
CeeGee Posted October 20, 2008 Author Share Posted October 20, 2008 This is what i whant, still testing particle_fracture_rotate3.movFetching info... Quote Link to comment Share on other sites More sharing options...
Rudinie Posted October 21, 2008 Share Posted October 21, 2008 Ah, i get the point, the problem is that the normals from the points you feed into your popnet only get read on the birth-frame in POPS. When you start right away with a bulge in the grid, the normals do get passed on. So to get this to work, you would net POPS to read the normals of the input points on EVERY frame. Hmm, no idea how to do that yet. Attached your file with some slight adjustments to get the normals to work in pops (just on the first frame though) Rudi particle_rotate2.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Owl Posted October 21, 2008 Share Posted October 21, 2008 like that? particle_rotate_3.hipncFetching info... Quote Link to comment Share on other sites More sharing options...
Rudinie Posted October 21, 2008 Share Posted October 21, 2008 Owl said: like that? particle_rotate_3.hipncFetching info... Yes! That's it! Now that's a powerfull tool, the attribute transfer. Thanks, i learned something today! Rudi Quote Link to comment Share on other sites More sharing options...
