Sprite images don't render.
paleajed
Creating sprites...
As far as I can see I did everything correctly: VEX Decal shader with butterfly texture loaded into Sprite POP.
Sprite Procedural shader loaded into OBJ->Geometry->Procedural Shader.
Sprites show fine in the viewport.
Mantra though, only renders white square sprites.
What's wrong ?
sprites.hipnc
Edited by paleajed
Creating sprites...
What's wrong ?
Make sure you are passing "Cd" and "Alpha" attributes to your sprite procedural shader
