dodoer Posted October 17, 2008 Share Posted October 17, 2008 hi : help me ,I have houdini file to maya,how do? Quote Link to comment Share on other sites More sharing options...
Jason Posted October 17, 2008 Share Posted October 17, 2008 dodoer said: hi : help me ,I have houdini file to maya,how do? Look at FBX Export/Import. Quote Link to comment Share on other sites More sharing options...
CeeGee Posted October 17, 2008 Share Posted October 17, 2008 Or export in RealFlow bin format.. And import in Maya... Quote Link to comment Share on other sites More sharing options...
Starrider Posted October 17, 2008 Share Posted October 17, 2008 Here's a bgeo loader plugin for Maya: http://houdinistuff.com/ (great tool!) Quote Link to comment Share on other sites More sharing options...
Lucavfx Posted October 28, 2008 Share Posted October 28, 2008 (edited) I'm also considering various options to quickly and conveniently cache particles back to maya Has anybody successfully imported .bin files from houdini to maya? Does houdini natively outputs realflow genuine bin particle cache from the rop output drive (or file in write mode)? Should I include some additional attributes in order to have the particle loader in maya recognize the cache genuinly coming from realflow? Thanks Luca Edited October 28, 2008 by Lucavfx Quote Link to comment Share on other sites More sharing options...
melazoma Posted October 29, 2008 Share Posted October 29, 2008 (edited) Lucavfx said: I'm also considering various options to quickly and conveniently cache particles back to mayaHas anybody successfully imported .bin files from houdini to maya? Does houdini natively outputs realflow genuine bin particle cache from the rop output drive (or file in write mode)? Should I include some additional attributes in order to have the particle loader in maya recognize the cache genuinly coming from realflow? Thanks Luca I'm not sure about Maya, but I've been using the world-famous Real Flow plugin from xionmark to move particles from Real Flow to Krakatoa. It works wonderfully for what I needed to do: remap Real Flow's particle age to particle density, etc, then export out to .bin again. The RF import SOP gives you all the RF particle channels as point attributes, and the RF export SOP puts them all back--for what it's worth, Krakatoa works great with the exported bins. The plugin is available in source code here (Win32 compiled dll link is broken, you may have to compile it yourself): http://www.digitalcinemaarts.com/dev/real_flow/index.html EDIT: Realized that RealFlow doesn't export color. Edited November 4, 2008 by melazoma Quote Link to comment Share on other sites More sharing options...
Lucavfx Posted October 31, 2008 Share Posted October 31, 2008 Thanks I'll look into that! L Lucavfx said: I'm also considering various options to quickly and conveniently cache particles back to mayaHas anybody successfully imported .bin files from houdini to maya? Does houdini natively outputs realflow genuine bin particle cache from the rop output drive (or file in write mode)? Should I include some additional attributes in order to have the particle loader in maya recognize the cache genuinly coming from realflow? Thanks Luca Quote Link to comment Share on other sites More sharing options...
