kensonuken Posted December 4, 2008 Share Posted December 4, 2008 (edited) http://www.sfdm.scad.edu/faculty/mkesson/v...conversion.html when the code is same then it should give the same output... why do these things change ? is there anything globally defined differently? like certain constants? If the spec is different than others then how about other Illum functions like gloss or phong or oren give accurate results? but why is this happening? any specific reason? Edited December 4, 2008 by kensonuken Quote Link to comment Share on other sites More sharing options...
Jason Posted December 4, 2008 Share Posted December 4, 2008 They do mention they know of a difference in their implementation - I wonder what that is. One thing that does stand out is calculation of dPds/t derivatives will be different and this affects filtered functions. http://www.sfdm.scad.edu/faculty/mkesson/v...conversion.htmlwhen the code is same then it should give the same output... why do these things change ? is there anything globally defined differently? like certain constants? If the spec is different than others then how about other Illum functions like gloss or phong or oren give accurate results? but why is this happening? any specific reason? Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted December 4, 2008 Share Posted December 4, 2008 The implementations of specular() are different (as in: different models altogether) between VEX and RSL. And they're both proprietary. To have them both look identical you'd have to use your own specular model. Quote Link to comment Share on other sites More sharing options...
kensonuken Posted December 4, 2008 Author Share Posted December 4, 2008 (edited) thank you... apart from there is there any image quality difference between Renderman and Mantra? ( i mean according to your experience and observation ) Edited December 4, 2008 by kensonuken Quote Link to comment Share on other sites More sharing options...
Mario Marengo Posted December 4, 2008 Share Posted December 4, 2008 thank you... apart from there is there any image quality difference between Renderman and Mantra? ( i mean according to your experience and observation ) Image quality is comparable -- that is to say: they are both good (in my experience). Quote Link to comment Share on other sites More sharing options...
Jason Posted December 4, 2008 Share Posted December 4, 2008 Image quality is comparable -- that is to say: they are both good (in my experience). I completely agree. Each has particular strengths but the overall quality of image is very comparable, IMHO. Quote Link to comment Share on other sites More sharing options...
