OpenCL spec is released
digitallysane
I read an article somewhere that said that Nvidia was definitely going to support it on their next generation of cards, and that ATI was probably going to :).
I just wish I could remember where the article was for proof.
M
Yep, Nvidia and AMD/ATI will support OpenCL.
No official news from Intel that I can find, but they'd be a little crazy not to support it with Larrabee (especially since the next architectural enhancement to the i7 will include Larrabee's AVX (16-wide vector) instruction set). Lots of rumours out there, though.
As long as an OpenCL implementation has default CPU support, then I think its adoption will be more widespread. Having to write two versions of your algorithm, one for the GPU and one for the CPU (in case the user doesn't have a supported GPU) was a main concern of many of the developers I talked with an Nvision. Forever after, you have to keep them in sync, which is a developer's nightmare as the number of GPU algorithms in your code increases.
On the other hand, Microsoft isn't going to support it, presumably because they will support compute shaders in DX11. However, this would only be a problem if you had a pre-8x000 nvidia card, a pre-X1x00 ATI/AMD card, or one of those integrated graphics disasters from Intel, or an older driver that doesn't include OpenCL within the driver package.
yeah, that would suck.
Which is to be expected really :). Idiots.
M
