illuminance loop
sl0throp
I am trying to wrap my head around the illuminance loop and on how to approach establishing a lighting model within it. I would like to start very simple and just be able to gather the diffuse, specular, and reflection channels and pass those into deep rasters. I am able to construct my own shading models in VOPS and have dissected shaders but am left more than a little confused.
Can I construct my network within one loop or do I need a loop for each property that I would like to gather? The Sesi shaders seem to do this but I have also seen one where it seems like a regular network with a shadow, lambert spec some mults and adds kinda thing.
What node do I use to export my variable...diffuseExport etc that gets attached to the illum output?
Thanks for any pointers here...
s
There is always this post which I think is the best example which really explains things well.
Also, I did a simple video on this with my base understanding of the subject (if I follow your question correctly). Maybe it might help?
You can find it here titled "Part 3: Light Export Using Illuminance Loops"
Edited by geneome
