Houdini to MI
Hey guys!
I have a question about writing MI files from Houdini. We are attempting to integrate Houdini into our pipeline
but we have a Mental Ray farm.
Is it possible to export MI files that will render on Mental Ray standalone with Houdini Shaders? When I attempt to write
a MI file I get a default MR shader instead of the shader that is attached to my object. I am assuming this is because Mental Ray does not understand Mantra shaders and attaches
a default MR Shader. Is it possible to pump the output of a Mantra shader into a Mental Ray shader and have this include into
my MI?
Any help is much appreciated!
Thanks!
Walter
Hey guys!
my MI?
Thanks!
Walter
Hmm, Houdini comes with mental ray specific shaders, and those have to applied to render with mental ray... is this is what you tried?
Hey guys!
Sorry to hear that :)
No.
The only shaders that will work with mr are the mental ray one (goto shop, hit tab, anything in the mentalray sections).
my MI?
No, mainly because mental ray does not have a shading language (their attempt to copy and extend rsl called "metasl" is not production-ready and has no VM compiler, nor via C++ compile you can get stable shaders as of today). You need to rewrite them by hand in C++ via the mental ray API (we could help you in this, but do you really need to? :) ).
Just use VEX with Mantra or RSL shaders with a RenderMan renderer, once you see their strengths it you will ditch mental ray without remorse.
P.
Thanks guys!
That is what I thought regarding Mental Ray, I think we are going to try and get Mantra working.
I agree, I like Vex and Mantra much more than Mental Ray.
I will get back with you if I have any questions on setting up our farm to handle this.
Thanks!
Walt
I don't think you'll regret getting Mantra working -it's just getting better and better:) If you have any questions on it, we'd be happy to help out.
Thanks! we got it running on the farm now. Very exciting!
I do have a related question.
Yesterday I was attempting to bring maya's camera into houdini using the fault camera otl, but no matter what I did I could not get the camera
to match up. The position of the camera was fine but the images were off when it came to the lens parameter. I was finally able to get the camera to match using an fbx file. Really thought I need to be able to build a custom camera and update the camera from a chan file.
So, my question is. What is the math behind the camera conversion from maya to houdini? which parameters need a conversion?
Also, is this documented anywhere?
Thanks!
Walter
Thanks!
Walter
Maya Aperture is in inches where as Houdini's is in millimeters.
Houdini Aperture = Maya Horizontal Aperture * 25.4
Vertical ap = horizontal/aspect e.g. /1.777777 for HD
Ah! that worked great! That was simple! Thanks!
One day, someone with extreme patience and a lot of time will attempt to set up all the same parms and features of a Maya camera in Houdini. Boy does that camera have a lot of setttings! :) Certainly doesn't abide by the KISS principle of design.
