Wolfwood Posted April 24, 2003 Share Posted April 24, 2003 If your Houdini session is idle and you are bored why not play some Pong with the guy down the hall. And here is the Pong OTL. If the first time you play the paddles act a little iffy just play through it, it should go away. If it doesn't just stop the game (animation), go back to frame 1 and try again. If that doesn't work try to hit reset a few times. I'm going to sleep now..... jim. Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 24, 2003 Author Share Posted April 24, 2003 Before I pass out I just want to note that there are some examples of "opdef:" in conjunction with parameter callbacks in the OTL. OTLS are SOOOOO cool. There are two tiny little scripts bundled in and using "source opdef:/Object/pong10?xxxx" I can call the little monkeys. I need to go into Side Effects and start buying these people lunch. jim. Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 24, 2003 Author Share Posted April 24, 2003 Oh...and when playing single player.... fear the wave function. jim. Quote Link to comment Share on other sites More sharing options...
michael Posted April 24, 2003 Share Posted April 24, 2003 HAHAHA...VERY cool! btw your help file lists: Player 1: "a" Moves paddle up "b" Moves paddle down but it sould be "z" is there a way to keep score Quote Link to comment Share on other sites More sharing options...
Mcronin Posted April 24, 2003 Share Posted April 24, 2003 Fun stuff Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 24, 2003 Author Share Posted April 24, 2003 "b"? oops.... I'm fired. To be honest I had a score keeping function and also if the ball went out of bounds it would flash game over and reset the game. But with this extra stuff the game slowed down a lot. Then again it might just be my computer. I'll tweak it tonight. And release the OTL again. = ) jim. Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 25, 2003 Author Share Posted April 25, 2003 I added some new features, like a scoreboard and a game over function, etc. I'll upload the modified OTL once I figure out how to put custom expressions into an OTL. If you have any ideas let me know. jim. Quote Link to comment Share on other sites More sharing options...
Jason Posted April 25, 2003 Share Posted April 25, 2003 RFE: A key to reset! Or an Auto-Reset! RFE: Use the Network CHOP and make it network multiplayer! (This is great!) Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 25, 2003 Author Share Posted April 25, 2003 Both your suggestions have been logged. Part of the problem is I can't bundle expressions in the OTL. I'll see if I can make a little work around. jim. Quote Link to comment Share on other sites More sharing options...
michael Posted April 25, 2003 Share Posted April 25, 2003 I just love the fact that there are a couple of people at SESI working away on bundling expressions in an OTL...and the main need for it right now is PONG Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 25, 2003 Author Share Posted April 25, 2003 One of the main reasons I do these silly things is to test Houdini. The end result is good, but if Houdini gets improved because of it than thats great. Basically Pong is just another attempt at dredging up user and Houdini bugs. jim. Quote Link to comment Share on other sites More sharing options...
michael Posted April 25, 2003 Share Posted April 25, 2003 hehe...yeah, 'happy accedents' drive alot of R&D Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 25, 2003 Author Share Posted April 25, 2003 Ugh... I love OTLs but without being able to use custom expressions its making things tough. Regardless I got it mostly working with scoring and automatically ending the game. At which point you need to hit "r" to reset. Issues: The paddles when first used are still acting strange. Some setting I must be overlooking. Sometimes a CHOP network won't cook. Which means my little logic scripts don't get run. I tried to force the CHOP network to cook by exporting it to a null. (Just so you know why its there.) There are probably half a dozen other things too. I attached the working hip file istead of an OTL. jim. Pong.zipFetching info... Quote Link to comment Share on other sites More sharing options...
will Posted April 25, 2003 Share Posted April 25, 2003 that is simply smooth! mucho mucho fun! did i say yet that it was really cool? how about adding in single player where the computer paddle follows the ball? ball is the leader, paddle is the follower constrained to the Y axis with a speedlimit on Y-axis movement. now, if only we could hook up those old-school paddles instead of using the keyboard... will Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 25, 2003 Author Share Posted April 25, 2003 I could set it up to use take a mouse input instead of keyboard. Not a paddle....but it beats a keyboard. I'm gonna try Jason's idea and network it. I'll work on it later this weekend. I wanna get back to my SSS shader for a bit. jim. Quote Link to comment Share on other sites More sharing options...
will Posted April 26, 2003 Share Posted April 26, 2003 so, in order to make single player a bit more challenging than the wave function , i added a tiny bit to phong pong... however, it isn't working as i would expect and as the manual states...at least, the way i am understanding it heh. in the attached hip, i added a point sop in the ball object with a ty that references the centriod of the ball. using this, the idea was to fetch it into chops and add a small delay so that the computer paddle would follow the Y position of the ball with a little "human-like" delay hit play and you can see that the centroid expression is correctly extracting the Y position of the movement of the ball; however, the fetch chop doesnt seem to be picking up anything. anyone have any idea why this is happening? cheers to the ultimate pong game! will a few more ideas for the mix Pong02.zipFetching info... Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 26, 2003 Author Share Posted April 26, 2003 Open Source Houdini Pong. I never thought I see the day. jim. Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 26, 2003 Author Share Posted April 26, 2003 will said: hit play and you can see that the centroid expression is correctly extracting the Y position of the movement of the ball; however, the fetch chop doesnt seem to be picking up anything. anyone have any idea why this is happening? I had tried a variation of this. I also tried a geo. chop to fetch the point position etc. I think the problem is a infinite recursion error. Either nothing happens or the CHOP spits out and error. My guess is this... To do a proper collision with the right paddle the collision POP needs to know where the paddle is. However the CHOP controlling the paddle is asking the POP what position it should have indirectly through the SOPs. _POPs -> SOPs -> CHOPs -> POPs _ |_____<_____<____<_____<_____| What came first? The POP or the CHOP? jim. Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 26, 2003 Author Share Posted April 26, 2003 Ok, I just watched a Godzilla movie so I got all motivated and proceeded to kick around CHOPs till I got it to work. I used a geometry CHOP to fetch the ball's position. Then I used a record chop so I could keep the animation data. Then appended a feedback chop so the chain would be using the previous frame's data to prevent the infinite recursion error. Next I slapped down a lag CHOP. (My favorite CHOP of the week). Then exported. I added an additional parameter to the Pong OP called Computer Skillz. It controls how strong the lag is. I added a couple of other export CHOPs to the record and feedback chops in order to force them to cook. So now single player mode should acutal be half interesting. On to networking so Jason can school Marc. jim. Quote Link to comment Share on other sites More sharing options...
Wolfwood Posted April 26, 2003 Author Share Posted April 26, 2003 Poop, forgot the attachment. jim. Pong_1.23.zipFetching info... Quote Link to comment Share on other sites More sharing options...
