change velocity using CHOPs
mic
hello! i have a problem: i have the point which follows the path. i did it using exporting to geometry CHOP the curve, and the channel SOP. but the method is not principal.. and i want the point to follow the path with no changing velocity on the X axis for example.. how should i do this?
  stevenong said:
Sayden is pretty close with the Point SOP but instead of setting a value, you can connect the original point to the second input of the Point SOP, turn on Add Velocity & set X Velocity to $VX2 which means use the velocity value from the second input.
Cheers!
steven
thank you, Steven, thank you Sayden, seems that everything is ok, i post the scene!)
follow_path_with_constant_velocity_X.hipFetching info...
Edited by mic
