zasid Posted February 22, 2009 Share Posted February 22, 2009 Hey guys, I know its not the cutter support forum but m sure many of the Renderman geeks must be using it. I have setup renderman when i try to render a simple single frame rib doc generated thro cutter it shows render complete but no window pops up to show me rendered image?I check my lib and shader paths are correct ,am i suppose to change any environment variables in windows which i have no idea how to do please help. thanks Quote Link to comment Share on other sites More sharing options...
Alanw Posted February 23, 2009 Share Posted February 23, 2009 Hey guys,I know its not the cutter support forum but m sure many of the Renderman geeks must be using it. I have setup renderman when i try to render a simple single frame rib doc generated thro cutter it shows render complete but no window pops up to show me rendered image?I check my lib and shader paths are correct ,am i suppose to change any environment variables in windows which i have no idea how to do please help. thanks Hey Zasid, which renderer are you using? I am pretty sure Cutter uses Pixar's "it" as it's default display device, so you may need to edit this out in the generated RIB before rendering. (unless you have "it") Display "test" "it" "rgb" Generally, each render will come with a few display devices, so check your docs if you're unsure how to use them. 3Delight's default is "i-display" for example. It may be a paths problem though. Make sure your renderer and display device are added to your PATH environment variable. -Alan Quote Link to comment Share on other sites More sharing options...
zasid Posted February 23, 2009 Author Share Posted February 23, 2009 Hey Alan, Thanks I will have a look tonight. I am using render man. Can you tell me what I need to set in the Path environment variable and where to do that. Its may be this one that u get under mycomputer->properties->Advance->Env Variables . Where I go there I see RMANTREE and Some other RMAN Variable but I cannot find the RMAN.exe can you tell me how can I set up one for that. Manyt thanks zasid. Quote Link to comment Share on other sites More sharing options...
zasid Posted February 23, 2009 Author Share Posted February 23, 2009 (edited) Hey Alan,Thanks I will have a look tonight. I am using render man. Can you tell me what I need to set in the Path environment variable and where to do that. Its may be this one that u get under mycomputer->properties->Advance->Env Variables . Where I go there I see RMANTREE and Some other RMAN Variable but I cannot find the RMAN.exe can you tell me how can I set up one for that. Manyt thanks zasid. __________ [2] 1.37:44AM __________ 3DL ERROR P1029: cannot find display driver 'it' # Rendering C:\Cutter\test.rib ... RENDER COMPLETED: Errors: 1 --------------------SAMPLE CODE-------------------- Display "untitled" "it" "rgb" Format 427 240 1 Projection "perspective" "fov" 20 ShadingRate 1 it doesn't seems to work . Edited February 23, 2009 by zasid Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted February 24, 2009 Share Posted February 24, 2009 are you using PRMan or 3dlight as you renderer? Quote Link to comment Share on other sites More sharing options...
Alanw Posted February 24, 2009 Share Posted February 24, 2009 I think the "3DL error" suggests he's using 3Delight. Try changing this line in your RIB before rendering. Display "untitled" "i-display" "rgb" or Display "untitled' 'framebuffer' 'rgb' Quote Link to comment Share on other sites More sharing options...
TheAdmira1 Posted February 24, 2009 Share Posted February 24, 2009 good call... framebuffer should work... Quote Link to comment Share on other sites More sharing options...
zasid Posted February 24, 2009 Author Share Posted February 24, 2009 both of them dont work i use prman and 3deligt Quote Link to comment Share on other sites More sharing options...
zasid Posted February 24, 2009 Author Share Posted February 24, 2009 i cud be env variable problems also that i dont know how to set ?are there any video tutorial or tutorial to sort this issue out have be trying it for a day Quote Link to comment Share on other sites More sharing options...
zasid Posted February 24, 2009 Author Share Posted February 24, 2009 _ [11] 6.0:38AM __________ RENDER COMPLETED: but nothing pops up to show me my image. Quote Link to comment Share on other sites More sharing options...
zasid Posted February 24, 2009 Author Share Posted February 24, 2009 hey it worked thanks alot Display "untitled' 'framebuffer' 'rgb' Quote Link to comment Share on other sites More sharing options...
