The right install workflow in H9.5
jacys
What operating system are you on and what version of houdini are you using? Perhaps someone here has a build you can use.
And what have you tried so far that's failed?
Cheers
Marc
I use WindowXP 32bit, I just load OTL and didnt see anything.
  • 3 weeks later...
I think the readme file for the HOT tools describes where to put the .dll files with the install on windows.
I think you have to put the .dll's in houdini9.5/dso folder in your home directory (c:/Docuemnts.... blah .../your_name/houdini9.5/dso/) where houdinix.x has to have the current version number for the release you are running and the release that the HOT tools was compiled for. Houdini only looks for dso directories containing the .dll's in the HOUDINI_PATH.
Edited by old school
