hdri and environment light
A handy tip when using an HDR with the environment light :-
Create a spare float parameter on your env light label it exposure and name the parameter lower case "exposure" , in your light intensity float parameter add pow(2.0,ch("exposure")) . You are channel referencing the new exposure parameter. Leaving the lights intensity at 1 while you set all this up willg ive you a correct start point. Now when you use an HDR you can step down or up in F stops or half stops , just as if you were using a camera
Rob
