mattd Posted March 29, 2009 Share Posted March 29, 2009 I am wondering if any of the polygon formats support multiple uvsets, and if maya can read them. This forum does not let you seach for 'uv' so the search has come up dry. MD Quote Link to comment Share on other sites More sharing options...
Jason Posted March 29, 2009 Share Posted March 29, 2009 I am wondering if any of the polygon formats support multiple uvsets, and if maya can read them. This forum does not let you seach for 'uv' so the search has come up dry.MD I think Obj and FBX both support multiple sets of attributes, so you should be good with either. Quote Link to comment Share on other sites More sharing options...
mattd Posted March 30, 2009 Author Share Posted March 30, 2009 (edited) hmm, I have been trying them with no luck. I have tried point and vertex uv's, and the second set is always ignored in maya. FBX export from maya with multiple sets does work. Also the fbx file that houdini puts out reads back in fine to houdini. I think the maya import may be buggered. I'll slink off to a maya forum now.... I am pretty sure obj files don't work, since the export/ then reimport to houdini loses the multi sets. I think Obj and FBX both support multiple sets of attributes, so you should be good with either. Edited March 30, 2009 by mattd Quote Link to comment Share on other sites More sharing options...
villain Posted March 30, 2009 Share Posted March 30, 2009 you could export your object multiple times, once with uv1, then uv2, etc. then import them into maya and copy the uv's onto one object. of course if you have lots of uv's and objects, it will be quite a hassle in maya Quote Link to comment Share on other sites More sharing options...
marvelaugusts Posted April 5, 2010 Share Posted April 5, 2010 This plugin currently consists of an exporter, importer and a utility plugin for 3ds max and gmax for read and writing Gamebryo/Netimmerse related files. Report problems and ask questions here: [spam Begone!] A wiki for the 3ds Max plugins is available at: [spam Begone!] Enjoy! Quote Link to comment Share on other sites More sharing options...
