hatrick Posted April 12, 2009 Share Posted April 12, 2009 is the output of extraimageplanes without mplay locked in the apprentice version? somehow i can save my zdepth with mplay but the image is black when i output $F as a separate file (.exr) thx Quote Link to comment Share on other sites More sharing options...
hatrick Posted April 12, 2009 Author Share Posted April 12, 2009 (edited) neither it works with mplay i can view all my planes ore channels .... but i can not change the settings for color ore alpha for saving out?! what i m doing wrong Edited April 12, 2009 by hatrick Quote Link to comment Share on other sites More sharing options...
hatrick Posted April 12, 2009 Author Share Posted April 12, 2009 i figured out that the "show component" button has to be activated in mplay to get access to the C and A settings for saving out ... so far the issue with writing planes out to disk is not solved thx Quote Link to comment Share on other sites More sharing options...
Jason Posted April 12, 2009 Share Posted April 12, 2009 i figured out that the "show component" button has to be activated in mplay to get access to the C and A settings for saving out ... so far the issue with writing planes out to disk is not solved thx Apprentice only supports .jpg, or the proprietary .picnc or .ratnc formats. The picnc and ratnc formats both should allow your multitudes of planes to be written out. You can use .picnc in the Houdidni compositor without worrying about the watermark. The watermark will be burned into the image once you write your final image out to .jpg. Read this, if you like: http://odforce.net/wiki/index.php/HoudiniApprentice Quote Link to comment Share on other sites More sharing options...
hatrick Posted April 12, 2009 Author Share Posted April 12, 2009 apprentice HD here .... same thing ? additionally i d like to know how to pipe out an extra occlusion pass. For example with a GI lightshader generating the AO. thx Quote Link to comment Share on other sites More sharing options...
hatrick Posted April 12, 2009 Author Share Posted April 12, 2009 rendering a beatuy pass as exr to disk is working here.... only the extra plane is black but only when i write it to disk directly Quote Link to comment Share on other sites More sharing options...
hatrick Posted April 12, 2009 Author Share Posted April 12, 2009 somehow thats all a bit strange.... last time i checked the show components button and this let me set the resolution the color and the alpha channel .... this time it doesnot work again... very simple! i d like getting out a seperate channel on my C channel... whats wrong here? Quote Link to comment Share on other sites More sharing options...
hatrick Posted April 12, 2009 Author Share Posted April 12, 2009 seems to be a little bug with my version... sometimes it works sometimes not ... but the imageplane is always set to beauty (all planes) with exr... i figured that out now:) sorry for spaming around here guys...i m only a little disapointed bout that limitation. i d love to do some comping in nuke... so the other issues... how to get out an seperate occlusion pass (with GI lightshader for example) ... i was told to search for the outputvariables in the shopnetwork? i tested around with H10 PBR and Imageplanes... are there some limitations ?... can i get out as much passes i can render with micropoly ore raytrace? thx alot Quote Link to comment Share on other sites More sharing options...
