bhaveshpandey Posted May 7, 2009 Share Posted May 7, 2009 hey I'm glad that H10 got installed on my Ubuntu 9.04 but when I launch it, there are no icons for the shelf tools as well as anywhere on the the UI,,,,No Icons,, anyone else faced the issue?? Thanks PS: feels good to be back in this side of universe Quote Link to comment Share on other sites More sharing options...
majikal Posted May 7, 2009 Share Posted May 7, 2009 sound like graphic card issue... what card and what drivers do you use? Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted May 7, 2009 Author Share Posted May 7, 2009 (edited) i'm running Nvidia GeForce 8400M GS (8M series)....driver version 180.. Edited May 7, 2009 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 7, 2009 Share Posted May 7, 2009 (edited) you probably installed it as root. ls -l in your $HOME and check if the houdini10 directory has got permissions set. Either: 1) remove the houdini10 directory in your home whilst being root. or 2) sudo chmod +rw -r houdini10 to give that houdini10 folder the proper permissions. then launch houdini normally, it will recreate that directory, but this time as a normal user instead of as root. have a look at this thread for more info - it's all in there: http://forums.odforce.net/index.php?showto...amp;#entry59365 Edited May 7, 2009 by pclaes Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted May 7, 2009 Author Share Posted May 7, 2009 pclaes thanks a lot!! its working like a charm now :thumbsup: Quote Link to comment Share on other sites More sharing options...
ragupasta Posted May 8, 2009 Share Posted May 8, 2009 Sorry to semi-hijack this thread, but I figured this would be the best place to put it. Ive been using Linux for about a week now (no previous experience). Ive got Ubuntu 9.04 installed, and a little less than a week ago I installed H10 using a guide I found on Sesi forums. Ive not logged into Linux for about 3 days now, so I logged in today fired up Houdini, got the load screen, app loaded up, but thats it. I cant select or do anything. Easiest way to put this is, fire up Houdini, take a screen grab, set it as your wallpaper, now try using that wallpaper as Houdini. Its driving me mad. Im on a Geforce 8800GTS using 180x drivers. Everything is up to date on the OS side of things. It was working fine. However Ive uninstalled it, reinstalled it, uninstalled it again and nuked the download, re-downloaded it, re-installed it, same thing, only this time the installation gets as far as the licensing screen, and low and behold I (again) cannot select the damn choices. Here is a image of the latest install, look at the license screen, now try to click the "install apprentice licenses", cant do it?, neither can I Has anyone had this before? Quote Link to comment Share on other sites More sharing options...
ragupasta Posted May 8, 2009 Share Posted May 8, 2009 Also tried rolling back video card drivers and thats not the issue, as it still occurs. (My initial reason for the partitioning my HDD and putting Linux on there, is that x64-bit Vista drivers from Nvidia, crash within 10 minutes of Houdini starting, which makes Houdini totally unusable.) Quote Link to comment Share on other sites More sharing options...
pclaes Posted May 8, 2009 Share Posted May 8, 2009 Don't have linux in front of me, but did you turn off desktop effects - nvida turns it on by default which is not what you want? (it's the icon with the two shirts, the last tab I think in administration - not sure ) Quote Link to comment Share on other sites More sharing options...
edward Posted May 9, 2009 Share Posted May 9, 2009 It looks like you answered one of the installer questions strangely? It's trying to install into a directory named "yes". Quote Link to comment Share on other sites More sharing options...
ragupasta Posted May 9, 2009 Share Posted May 9, 2009 (edited) It looks like you answered one of the installer questions strangely? It's trying to install into a directory named "yes". Yes I flew through it to get a screenshot, I typed yes instead of [opt/hfs10.0.249.5] just for speed, (as this install was just for show purposes). However that is not the issue im afraid. Nor is turning off the visual effects, as I had already done that due to some thread's I read about it being prohibitive. I'll keep plugging at it, if it comes to it, I'll do a fresh install, as there isn't much on this partition, and what is on it is not worth keeping anyways. Cheers for the help guys. Edited May 9, 2009 by ragupasta Quote Link to comment Share on other sites More sharing options...
simonj Posted May 9, 2009 Share Posted May 9, 2009 Yes I flew through it to get a screenshot, I typed yes instead of [opt/hfs10.0.249.5] just for speed, (as this install was just for show purposes). However that is not the issue im afraid. Nor is turning off the visual effects, as I had already done that due to some thread's I read about it being prohibitive. I'll keep plugging at it, if it comes to it, I'll do a fresh install, as there isn't much on this partition, and what is on it is not worth keeping anyways.Cheers for the help guys. Sounds mighty wierd, are you running 9.04 Jaunty? I'm noticing an error on line 811? Is that common, I was thinking; isn't most of houdinis interface built on python? so an error connected to python maybe can be the problem? Also, are you running the install authorized? like sudo ./install.houdini I got a bunch of wierd errors when I didn't do that. Quote Link to comment Share on other sites More sharing options...
ragupasta Posted May 9, 2009 Share Posted May 9, 2009 Sounds mighty wierd, are you running 9.04 Jaunty? I'm noticing an error on line 811? Is that common, I was thinking; isn't most of houdinis interface built on python? so an error connected to python maybe can be the problem?Also, are you running the install authorized? like sudo ./install.houdini I got a bunch of wierd errors when I didn't do that. Yeah Im running Jaunty. Im not 100% of the Houdini interface coding, yes its heavily Python afaik, but I read somewhere H-Script it still playing a part. Maybe Edward could clarify that, as I dont know. As for the install, they way ive been doing it is.... (houdini download is un-archived in documents folder....) [opens terminal] sudo -s password for SoiFon# ***** root@SoiFon# cd /home/glenn/Documents/houdini10.0.249.5 root@SoiFon# ./houdini.install .......the installation process begins..... Ive also tried it with the alt+f2, gksudo nautlius (run with file...) and I gets the same thing. Its just really odd. Perhaps its something Ive done to upset the apple-cart, but what Im not sure, as ive not played with Linux a lot yet since I have a lot of reading up to do on the OS first. Cheers. PS: Im not in Linux now, so that terminal type up there ^^ is from mind. Quote Link to comment Share on other sites More sharing options...
edward Posted May 10, 2009 Share Posted May 10, 2009 Your installation process seems different from InstallingHoudini. It might where your python problems come from. I'm not sure about this, but can you use the License Administrator from your Linux app menu? If you can, then you can just do manual apprentice licensing: http://www.sidefx.com/index.php?option=com...&Itemid=319 Quote Link to comment Share on other sites More sharing options...
simonj Posted May 10, 2009 Share Posted May 10, 2009 Also, your 100% sure you got the right version of Houdini downloaded? Because I didn't and that was a problem, hehe. If you running 64bit 9.04 Jaunty you probably downloaded the "amd64" one. In that case your houdini tar should be named: houdini-10.0.249.5-linux_x86_64_gcc4.1.tar.gz Maybe we could compare some information since I'm running 9.04 Ubuntu too, with a working houdini. Unfortunately I don't know what information should be compared. hehe Anyway, you could always try following the steps exactly after the "InstallingHoudini" tutorial that edward linked, there's not much difference, but it might work. Quote Link to comment Share on other sites More sharing options...
ragupasta Posted May 10, 2009 Share Posted May 10, 2009 (edited) Your installation process seems different from InstallingHoudini. It might where your python problems come from. I'm not sure about this, but can you use the License Administrator from your Linux app menu? If you can, then you can just do manual apprentice licensing: http://www.sidefx.com/index.php?option=com...&Itemid=319 As for the installation process, I googled on how to do it, and up popped this thread http://www.sidefx.com/index.php?option=com...pic&t=14289 I followed the advice from SYmek's post #2. Is there any difference from me typing sudo -s to be root, over typing sudo ./ihoudini.install ? Also edward, houdini says inside the terminal that it is installed, but its not. There is no side effects folder in the app menu. simonj Yeah thats the version im using, see screenshot... Edited May 10, 2009 by ragupasta Quote Link to comment Share on other sites More sharing options...
ragupasta Posted May 10, 2009 Share Posted May 10, 2009 Actually I got it working. The ONLY thing different was ive changed my monitor over.Perhaps it was a monitor issue, I dunno, but It's working fine now. Quote Link to comment Share on other sites More sharing options...
simonj Posted May 10, 2009 Share Posted May 10, 2009 Actually I got it working. The ONLY thing different was ive changed my monitor over.Perhaps it was a monitor issue, I dunno, but It's working fine now. Wierd. :S I actually experienced something much like it today while working with houdini, suddently all buttons stopped working and I thought "you got to be kidding me". But I rebooted and it hasn't happened since. Glad you figured it out though! (OT: Is that Titus from FFX on your avatar? That's an awesome game. ) Quote Link to comment Share on other sites More sharing options...
ragupasta Posted May 10, 2009 Share Posted May 10, 2009 Yeah it is Tidus from FFX. I love that series. I think the environments they create are visually stunning! Ontopic: Thanks to all you guys for helping me out! Quote Link to comment Share on other sites More sharing options...
