from where to start in render ..... your advice !!!
hi evryone i want to say that i don't know any thing about render and how it is work and where and how to use expression in mantra and the vex expression for shading and how to do shader and i also can't understand what is the normal information in rendering and how to control it
so can anyone give me any advice about some tutorial about this for beginner or some video that help you to understanding this .
thanks for all.
thanks for all.
Hey there
you could start by going through
http://www.sidefx.com/index.php?option=com...&Itemid=132
I know that CMI vfx have a course on rendering
I think that if you're new to rendering, then getting into shader writing and want to understand the theory behind "normals" etc -
look introduction to render renderman guides and pdf's online or buy a book on that because what you'll learn there will be applicable to mantra. - just to broaden your theory.
When you start getting into pbr and mantra specific shaders, ie volumetric rendering etc
I would start by reverse engerneering shaders SESI supply with houdini, go into the vop networks on basic materials.
all of this will be confusing if you havent got a small grasp of what the basics, so i wouldnt start there but it does give u a little room to play around in.
:blink:
not sure why you'd need to use expressions...
the best thing to do is start with the very basics...
the links that aracid posted are a good start...
also:
and during each tutorial, have a look through the help cards for each node (the little ?) and read up on what the different parameters do...
then make a simple scene or grab something from here:
http://www.3drender.com/challenges/index.htm
and just play around...
the goal isn't to create a perfect render but to learn /how/ to render...
also, don't bother trying to write shaders until you get comfortable with lighting and rendering, there are plenty of good shaders that come with Houdini...
as you get deeper into it, start a thread in the WIP section and post any questions you have...
