Any one show example for multi input python sop?
davylew
I want my python sop has 4 inputs.
geo = hou.pwd().geometry()
this code gave me one instance object of first input geometry.
How do I get object to the second input?
Hey,
assuming that in general 4-inputs operators change only first input, there is no magic here, you can get the read-only geometry from node's connectors like in any other place of Houdini:
geo2 = hou.pwd().inputs()[1].geometry()
Note that hou.Node.inputs() returns variable length tuple not empty reference, so you need a logic for that ( or smarter way doing this ;) ).
hth,
skk.
Thx SYmek & edward !!!
Another question is how create Python sop node with mutil inputs unknow the inputs number (like merge sop node)?
I want to manage different data flow and using ADD OR MIX to process those like layer structure.
