Procedural Particle Collision
athomas
I have to particle systems setup and like to trigger a birthing event when at least 30% of the particles have collided from the two different sources.
I was thinking of some 'if - then' statment or via a VEX network, but not quite sure.
Any ideas to create this procedural would help.
Cheers
Andre
Lukich,
Thanks for the reply, but I am after a solution which doesn't rely on SOP's.
Basically I want to get the following:
count particles at every frame for soucres A & B
get the number of particles from A colliding with B
if the number of collisioned particles is more than 30% of total particles in the scene
then birth particles from source C (or location)
Now ideally I would like to do this with a VEX Pop.
Cheers
Andre
