bhaveshpandey Posted June 21, 2009 Share Posted June 21, 2009 (edited) i dunno if anyone else has faced this issue.. problem is that i'm not able to render with newer version of mantra..but only with H8 mantra.. i do not get any error messages but the renderer doesnt just show up..even if Mantra is opened and then if I hit render nothing is initiated though i could use H8 i would still wanna know why this is happening. running Houdini 10.0.295 thanks EDIT: also the H8 Mantra is not rendering any shadows..i also tried by applying a pyro shader to a sphere converted into a fog volume but again if i select new mantra node for rendering the frame nothing happens...and if i use H8 Mantra, there are no shadows in the render....ironically the image rendered using VIEW MANTRA (default view render) renders the image with shadows any suggestions?? Edited June 21, 2009 by bhaveshpandey Quote Link to comment Share on other sites More sharing options...
dan_cgi Posted June 22, 2009 Share Posted June 22, 2009 Hi there, i had the same problem running 10.0.295. I could render with the default render but when i wanted to use a mantra render... nothing. I've taken this version off and am now running one of the daily builds, 10.0.307 and it works fine. Hope that this helps Quote Link to comment Share on other sites More sharing options...
bhaveshpandey Posted June 22, 2009 Author Share Posted June 22, 2009 hey thanks dan....gonna try that out then.. i really hate uninstalling and all these hassles..but its worth it Quote Link to comment Share on other sites More sharing options...
