UV-problem with stucco-like materials
skazkaPiter
the s and t you see on the Global VOP are the parametric coordinates per primitive.
whereas uvCoords lets you read the uv point attribute on geometry (the UVs you create yourself); most of the time u will usually want to use this one.
but sometimes it's also usefull to use the parametric ones, like for a NURBS surface for example where the 0-1 spans over the whole surface.
Cheers
Edited by geo
mangi, its not fixing problem...
geo, thanks for your explanations. But answers generate new questions..
how can i convert such N-poligon to NURBS without changing geometry?
i made something. that works in this example, but I think its not good, its crazy thing :)))
maybe I need modeling with NURBS from the beginning???
May be another, shader - solution? As i can see all displase shaders are equal with different type of noise, and all of them use parametric st. what kind of operators I need multiply noise to, to get result on my UV??
crazyNurbs.hipnc
