rotating shape in VOPs
varomix
Hi
First and I thing the easiest is, how do I rotate a shape in VOPS?, let's say I have a rounded hex and I wanna rotate that 90 degrees
I'm making some custom shapes compositing ( by a simple add) several shapes.
That lead to my next question, I've made a pattern, combining several hexagon shapes. (Rounded Hexes), and I've had to mess up with the S and T to deform that a little, so now, when I try to hook up the uvs, the pattern looks wrong ( obviously, till now :D), so my question is, is there a way to just cook that, bake it, or something like that, so that I can use my uvs?
This actually could be that the transform question could answer both.
Thank you
Edited by varomix
Guest Swann
Hi Varomix,
1) Try this OTL I made during my renderman voyages some time ago. It's VOP version of rotate2d renderman function.
2) Have to see your Hip to tell something about your problem with uv's.
EDIT: In the file above you don't have any UV's but I supose this is different file than that in your first post.
2d_Rotate.otl
Edited by SWANN
Thank you Swann
This is what I'm doing
I think I'm done with the pattern now, I need to clean it up, make some parameters, and pack it in to an otl, also I need to work on the color/shading
part of the metal.
any comments/suggestions are welcome
thank you
