br1 Posted July 14, 2009 Share Posted July 14, 2009 Hi, I have a small network of nodesdriven by motionfx that I'd like to use to drive the animation of different objects in another hip file. I thought to myself, ok let's make a tool out of this network and use that tool in my other file. I Collapsed all those nodes into a Subnetwork. Yet everything still works as intended. If I plug a box or cylinder into my subnet input 1, everything moves as it should. Now how do I make a tool out of this subnet1 node ? I I try to edit the parameters and expose a few more from my nodes, everything stops working and my parameter window starts with Input #1 Label, Input #2 Label, Input #3 Label, etc... before showing my custom parameters. I guess I'm doing it wrong. I watched a few 3Dbuzz videos but didn't see what are the wrong steps I did. I also took a look at the tool Masterclass but it's a bit too high level for me at the moment. I can post my basic file, but I don't think it's really necessary. I just want a bit more information on the workflow. thanks Br1 Quote Link to comment Share on other sites More sharing options...
michael Posted July 14, 2009 Share Posted July 14, 2009 if you're talking about building HDAs Jeff Wagner has a series of tutorials on his Old School Blog: http://www.sidefx.com/index.php?option=com...&Itemid=216 http://www.sidefx.com/index.php?option=com...&Itemid=216 http://www.sidefx.com/index.php?option=com...&Itemid=216 http://www.sidefx.com/index.php?option=com...&Itemid=216 also the documentation will be valuable to look through. Quote Link to comment Share on other sites More sharing options...
br1 Posted July 14, 2009 Author Share Posted July 14, 2009 Hi Michael, I hadn't see Jeff's blog about HDA, so I'll have a look at them tomorrow. The video seem to be done with Houdini 8. As I'm a newcomer and didn't play with Houdini before version 9, do you think those still apply ? About the documentation, I was willing to learn a bit more about the Subnetwork surface node. But when using the help, I'm having a problem. The doc says : "Please refer to sub-networks for a complete discussion and an example of how to use sub-networks." But when I press the link which refer to http://localhost:48626/basics/organize, I end up on an error page, as if that part of the documentation was nonexistent. Am I alone here, should I reinstall ? Thanks Bruno Quote Link to comment Share on other sites More sharing options...
