ITdreamer Posted July 19, 2009 Share Posted July 19, 2009 Hi I am trying to setup network rendering with mantra, but at this monet I didn't have a lot of success. I have 2 machines: vfxstation01 (main host) and vfxstation02 (hetwork host). For test: I want the image be rendered only by the network host. Both machines have 2 CPUs with 2 Cores + Hyper Threading, so on both of machines I see 8 cores. Now, to render: On vfxstation01 I open my scene, and in mantra ROP I disable "Use Max Processors", then to the mantra command I add "mantra -H vfxstation02" and press Render. According to Mantra Docs this will render my image using 1 core from vfxstation01. But after 3-5 seconds I get error in mantra ROP, and in console I get: master@vfxstation01:~$ Generating Image: vfxstation02 (512x512) Plane[]: Of[3] (16-bit float) mantra: Could not open imager Error: Failed to create file "null: : Permission denied". What does it mean? I understand that something with permissions, but what to do with this I don't know. By the way, both machines ping each other, so the ntwork is ok. I also found that when I press Render on vfxstation01, on vfxstation02 I immediatly get mantra process. It appears in the process list for few seconds, and then dissapeares, and I get error in ROP, and that text in console. What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
edward Posted July 19, 2009 Share Posted July 19, 2009 MantraRemoteRendering Quote Link to comment Share on other sites More sharing options...
ITdreamer Posted July 19, 2009 Author Share Posted July 19, 2009 edward said: MantraRemoteRendering I already read it. I have 2 machines (vfxstation01 and vfxstation02), and everything is ok when I render separetly, but when I whan to use both machines in render - it becomes a problem My tests on vfxstation01: 1) mantra (default settings. ) Everything is ok. Mantra renders using about 75-85% CPU. 2) mantra -H vfxstation01 (the same as 1, but I spesified the name of the local machine. Mantra renders using about 65-75% CPU. Little bit strange! ) 3) mantra -H vfxstation02 (network rendering using only the second machine). Mantra renders using about 75-85% CPU of the second machine. ) 4) mantra -H vfxstation01, vfxstation02 (network rendering using both machines). Mantra renders quits with error, and in console I get Generating Image: vfxstation02 (512x512) Plane[]: Of[3] (16-bit float) mantra: Could not open imager Error: Failed to create file "null: : Permission denied". 5) mantra -H vfxstation01, vfxstation01, vfxstation02 (the resul is the same as in 2) 6) mantra -H vfxstation02, vfxstation02, vfxstation01 (the resul is the same as in 3) How can I use both machines to render? What am I doing wrong? Quote Link to comment Share on other sites More sharing options...
edward Posted July 20, 2009 Share Posted July 20, 2009 In that case, maybe it's a recently introduced bug. I'd try submitting it. Quote Link to comment Share on other sites More sharing options...
kubabuk Posted July 20, 2009 Share Posted July 20, 2009 Are you testing this on win, linux...Why don't you try instead of names, static IP addresses? Quote Link to comment Share on other sites More sharing options...
ITdreamer Posted July 20, 2009 Author Share Posted July 20, 2009 kubabuk said: Are you testing this on win, linux...Why don't you try instead of names, static IP addresses? Aliluia! Friends, the solution was a little bit stupid! The problem was in space between hostnames!!!!!!!!!!!!!! mantra -H vfxstation01, vfxstation02 (gives an error) mantra -H vfxstation01,vfxstation02 (works fine) Quote Link to comment Share on other sites More sharing options...
