circular flow to simulation
alpotnis
hi .. i have been trying to work out a tyre burn out simulation using pyro effects. what i am struggling with is the circular motion i need to give the smoke as the tyre starts rotating. I need a force field which work like the 'vortex' force in 3dmax...
there is a vortex force in DOPs but you can also build your own -force-type-thingy
have a look at the fieldforce-dop,
basicaly create your "vortex-geometry" (in Sops) and create vectors which are the "force-vectors" (and name them "force")
in Dops use the sop-geometry node to import the geometry and use the forcefield-dop
Seb
Thanks for the reply Seb.. I've never used fieldforce before, but as i understand that its a force which can take any geometry (dynamic object) and make it work like a force field... pls correct me if i am getting this wrong.
However, this is what i quite don't understand: 'create vectors which are the "force-vectors"'
Can u please elaborate this.
-alok
