syzmatrix Posted August 5, 2009 Share Posted August 5, 2009 hi guys,long time no see . I am trying to get some fluid erosion effects. I use a lot of boxes interacting with fluid. And at each frame I get the fluid speed near each box, transfer it to the center point of the box, then the box with max speed should be deleted. So the effect like the boxes are disappeared frame by frame. Now the problem comes, I can not keep the state of the boxes in last frame. It always eroded from the first state. What I wish is the boxes are eroded little by little. So how can I keep the shape interact with fluid from frame to frame. Hope some nice guy can help me. the file is attached. fluid_erosion2.hip Quote Link to comment Share on other sites More sharing options...
mrice Posted August 5, 2009 Share Posted August 5, 2009 (edited) hi guys,long time no see . I am trying to get some fluid erosion effects. I use a lot of boxes interacting with fluid. And at each frame I get the fluid speed near each box, transfer it to the center point of the box, then the box with max speed should be deleted. So the effect like the boxes are disappeared frame by frame. Now the problem comes, I can not keep the state of the boxes in last frame. It always eroded from the first state. What I wish is the boxes are eroded little by little. So how can I keep the shape interact with fluid from frame to frame. Hope some nice guy can help me. the file is attached. The "feedback" example in this thread might help: also check out the "odforce attribute simulator" on the exchange: http://www.sidefx.com/index.php?option=com_wrapper&Itemid=139 Hope that helps! Edited August 5, 2009 by mrice Quote Link to comment Share on other sites More sharing options...
syzmatrix Posted August 5, 2009 Author Share Posted August 5, 2009 thax very much for your reply. it is really a enlightment for me. Quote Link to comment Share on other sites More sharing options...
