rd1010 Posted August 14, 2009 Share Posted August 14, 2009 (edited) This problem is baffling me and starting to get discouraging.. I use another software to do NURBS modeling as this is not houdini's strongest point and I can do much better models in other programs. When I import these models that started out as NURBS (have tried it either as poly .obj, .3ds, fbx or as nurbs igs) I am unable to convert the object to particles or to use it as a solid body in a particle simulation. When I click convert to particles it just keeps cooking but never finishes.. with objects that started as poly it works after not very long. Also, these are not all that complex of models and I have tried making them as low poly as possible (after converting to obj, 3ds, fbx, etc) I don't know what to do as this is important to make the things I want to make with particles.. would appreciate any input from anyone who may have also had this issue. edit: I have tried making the nurbs models in different programs including rhinoceros and moi.. I am pretty sure this problem is true for a nurbs model created in any software besides houdini. Edited August 14, 2009 by rd1010 Quote Link to comment Share on other sites More sharing options...
sibarrick Posted August 14, 2009 Share Posted August 14, 2009 Could you post an example model we can take a look at? Quote Link to comment Share on other sites More sharing options...
rd1010 Posted August 14, 2009 Author Share Posted August 14, 2009 (edited) Here are 2 geometry files, both originally from a NURBS model from a program called Moi. The main thing that this is causing problems for me is not being able to use these objects as a rigid body in a particle simulation. http://siliconvalley1-odesk.s3.amazonaws.com/bowl.obj http://siliconvalley1-odesk.s3.amazonaws.com/bowl.igs (click save as to save as the object file type) For example, putting a sphere of liquid above it and having it fall onto it.. either it won't cook it (just takes for ever never completes) or it will act like it has and then the fluid will just pass through like its not there. I'd post a hid file but I'm using the apprentice version so not sure it would work for others. Edited August 14, 2009 by rd1010 Quote Link to comment Share on other sites More sharing options...
dbukovec Posted August 14, 2009 Share Posted August 14, 2009 This is bad geometry, it has double caps (noting will fall inside it is closed), deleted all 4 caps, yes they are doubled, and used capSOP to add proper caps, this way a proper sdf can be generated for it, this is for rbd. To have particle fluids fall into it, you have to add thickness, if you dont have thickness, sdf cannot be generated. Quote Link to comment Share on other sites More sharing options...
rd1010 Posted August 14, 2009 Author Share Posted August 14, 2009 Thanks.. yeah I forgot to delete the caps but I had been deleting it in tests in houdini so that wasn't the issue itself.. thanks, the thickness is what I was leaving out then.. that helps a lot so I will try again and hopefully it will work for me. Quote Link to comment Share on other sites More sharing options...
rd1010 Posted August 15, 2009 Author Share Posted August 15, 2009 I can't seem to figure out how to add thickness to an imported piece of geometry as I don't see a SOP for it.. any info is greatly appreciated. Quote Link to comment Share on other sites More sharing options...
edward Posted August 15, 2009 Share Posted August 15, 2009 Try selecting all the primitives and then using PolyExtrude. Quote Link to comment Share on other sites More sharing options...
dbukovec Posted August 16, 2009 Share Posted August 16, 2009 yes, first use convert SOP to convert your nurbs to polys, then polyextrude with output back, and you will have proper object for collisions Quote Link to comment Share on other sites More sharing options...
