sea Posted August 22, 2009 Share Posted August 22, 2009 Hi: guy: I make a explosion by pyro tools ,then I got a problem when I put noise on it .just noise base on density . no animation . but it got a noise pop on frame 50 very times . could you help me to fix it? I use houdini 10.0.295 here is the video : http://www.vimeo.com/6216117 thank you very much Quote Link to comment Share on other sites More sharing options...
itriix Posted August 22, 2009 Share Posted August 22, 2009 (edited) yeah take a look at the end of this post: http://forums.odforc...9259-pyro-tool/ make sure that you're Start Frame and Reset Rate in the VEX Pyro Shader are the same as the Initial Reset Frame and Reset Every Frame values in the pyrosolver. use the same values in the VEX Pyro Shader > Settings tab: Start Frame and Reset Frame as you are using in the pyrosolver > Advanced > Rest Field tab: Initial Reset Frame and Reset Every Frames. To be honest, i'm still having issues with this also, because even when i set the values to 1 and 50 in both, the popping still occurred and so the only fix i found was setting these values to 1 and 60... i'm waiting to hear a response as to "how to know" what values to pick for these values. Supposedly 1 and 50 should work. but... for me it isn't. I'm curious if when you change your values in both to 1 and 50 if that will fix your problem... or if you will need to do 1 and 60 as well. So, hope that helps out. Cheers, Jonathan Edited August 22, 2009 by itriix Quote Link to comment Share on other sites More sharing options...
sea Posted August 24, 2009 Author Share Posted August 24, 2009 thank you very much yeah take a look at the end of this post: http://forums.odforc...9259-pyro-tool/ make sure that you're Start Frame and Reset Rate in the VEX Pyro Shader are the same as the Initial Reset Frame and Reset Every Frame values in the pyrosolver. use the same values in the VEX Pyro Shader > Settings tab: Start Frame and Reset Frame as you are using in the pyrosolver > Advanced > Rest Field tab: Initial Reset Frame and Reset Every Frames. To be honest, i'm still having issues with this also, because even when i set the values to 1 and 50 in both, the popping still occurred and so the only fix i found was setting these values to 1 and 60... i'm waiting to hear a response as to "how to know" what values to pick for these values. Supposedly 1 and 50 should work. but... for me it isn't. I'm curious if when you change your values in both to 1 and 50 if that will fix your problem... or if you will need to do 1 and 60 as well. So, hope that helps out. Cheers, Jonathan Quote Link to comment Share on other sites More sharing options...
