Writing VEX SOPs
Stremik
I'm tying to write an SOP OP that would allow multiple inputs.
How is it usually taken care of?
For instance I want to be able to pipe two sphere OPs in to this one and modify appearance of the spheres individually. Based on the R of each sphere.
Bigeer R of the sphere will resault in bigger displasement of the surfase of this individual sphere and vice versa.
Any help?
Thank you!
OK. Let me put it this way.
When I do "Create Type From" in Houdini, I'm presented with an option
to spesify a minimum and maximum numbers of inputs.
How do I do it in VEX by hand? How does a custop VEX OP reads in inputs
and tells them apart?
Thanks!
Doesn't this work for you?
I think he is trying to do it by hand.
Try these out.
#pragma opname [your opname]
#pragma oplabel [your op's label, (the friendly name)]
#pragma opmininputs [min number of inputs]
#pragma opmaxinputs [max number of inputs]
jim.
I don't see anything off the bat that would tell which input the point is coming from. For second place..... you could always append a group SOPs right before each of the inputs. Then use the ingroup() function.
jim.
BTW. I wander if you happen to know wether "Quick Function Reference" includes oll of the VEX functions or is there something else?
It seems like this is the case. For instance, I couldn't find "maxinputs" and "mininputs" pragmas in there.
Try these out.
jim.
You're right. I have missread this topic... (I think it's because of Stremik's reply. It made it look as if he was talking about VOPs).
Please excuse me for the inconvenience :ph34r:
The quick reference is here $HFS\houdini\vex\html\quickref.html
and the pragmas are here
$HFS/houdini/vex/html/compiler.html#cg_pragma
Those that I listed I found by creating a VOP with multiple inputs then started digging through the vex code. :)
jim.
I've tried this with SOPs but it wouldn't show any VEX code. :(
Don't be ridiculous man.
There can't be any.
Try right clicking VOP and choose "View Code". That should work. :unsure:
I'm sorry, I wasn't trying to be mean or anything. I just wanted to make sure we were all on the same page of music. :D
jim.
