crunch Posted September 14, 2009 Share Posted September 14, 2009 Recently, I ran into a case where I wanted to import line art generated in inkscape into Houdini. I tried saving .eps, but geps wouldn't parse the .eps generated by inkscape. This little Python program did the trick for me though, so I thought I'd share it. It uses the little known .d format (which makes it really easy). #!/usr/bin/python import sys, os def parseEPS(ifp, ofp): for line in ifp.readlines(): args = line.split() if len(args) == 3: if args[2] == 'moveto': ofp.write('m %s %s 0\n' % (args[0], args[1])) elif args[2] == 'lineto': ofp.write('d %s %s 0\n' % (args[0], args[1])) parseEPS( sys.stdin, sys.stdout ) It just reads from stdin and writes to stdout. You could probably easily turn this into something more useful. Example usage: % eps2d < foo.eps > foo.d It's not rocket science, but I thought I'd share. Quote Link to comment Share on other sites More sharing options...
varomix Posted September 14, 2009 Share Posted September 14, 2009 Hi I export as illustrator (.ai) from inkscape and that works fine in Houdini Quote Link to comment Share on other sites More sharing options...
dynamoanders Posted November 29, 2010 Share Posted November 29, 2010 Hey guys. I´m trying to import Illustrator files, but I have no success at all, it first just gave me an error, sying that it could´t import the geo, but then I tried some stuff, read in the help etc, remebered the old Maya trick, that I had to save it as a illustrator v10. Now I get the geo in, but I can´t visualize it. Do you guys have any settings for saving out illustrator files that you could share? Like if there´s a special thing that you should tick in or something. When I try with .eps, it gives me an error, but with .ai, i somehow get the file in, but can´t see it. Thanks guys. Awsome tutorials for Houdini by the way (pulverize effects and autofence). Cheers //Anders Quote Link to comment Share on other sites More sharing options...
varomix Posted November 29, 2010 Share Posted November 29, 2010 Hey guys. I´m trying to import Illustrator files, but I have no success at all, it first just gave me an error, sying that it could´t import the geo, but then I tried some stuff, read in the help etc, remebered the old Maya trick, that I had to save it as a illustrator v10. Now I get the geo in, but I can´t visualize it. Do you guys have any settings for saving out illustrator files that you could share? Like if there´s a special thing that you should tick in or something. When I try with .eps, it gives me an error, but with .ai, i somehow get the file in, but can´t see it. Thanks guys. Awsome tutorials for Houdini by the way (pulverize effects and autofence). Cheers //Anders Thanks Anders, I always export it as .ai version 8, if you want to used more recent versions uncheck the use compression flag, using compression sucks hope that helps Quote Link to comment Share on other sites More sharing options...
