kensonuken Posted September 18, 2009 Share Posted September 18, 2009 Ive been trying to solve the sss puzzle ... I rendered out the point cloud using the sss scatter sop and then used a skin sss shader from material library by giving the path to the point cloud which is generated in the scatter sop but..... I finally get something which doesnt look real... im completely fed up... pls help me... Quote Link to comment Share on other sites More sharing options...
kumpa Posted September 19, 2009 Share Posted September 19, 2009 On 9/18/2009 at 7:39 PM, kensonuken said: ... im completely fed up... try to eating little less i used wax shader and everything works normally in 10.0.374. see attached file ssss.rarFetching info... Quote Link to comment Share on other sites More sharing options...
kensonuken Posted September 19, 2009 Author Share Posted September 19, 2009 oops it was working well i havent checked in gamma 2.2 ... it was faintly visible.... anyway thanks... but somewhere ive seen people generating point clouds at the sop level after the displacement has done... i believe there must be some otl.... Quote Link to comment Share on other sites More sharing options...
varomix Posted September 19, 2009 Share Posted September 19, 2009 you could apply your displacement in SOPs with a VOPSOP, use that only for generating the point cloud, you might need to subdivide the geometry a little to get the detail. Quote Link to comment Share on other sites More sharing options...
