br1 Posted October 6, 2009 Share Posted October 6, 2009 Hi, I'm looking for a solution to this problem. I have two objects. A is an extruded and shattered Font and act as RBD fractured object. B is a box (with a few divisions) that acts as a static object. When I animate B's transforms to smash it into A, I get the correct behaviour, the dynamics react and object A explodes. If I want to use a wave deformer to animate object B instead of transforming it, I cannot get B to interact with A. I enabled deforming geometry in the solver, but it doesn't seem to be enough. I guess I miss something. I attached my example file, hoping someone can shed some light on that problem. Thanks Bruno deforming_static_rbd.hipnc Quote Link to comment Share on other sites More sharing options...
rbowden Posted October 7, 2009 Share Posted October 7, 2009 Hello, Inside your dopnet there is a checkbox for 'Volume Velocity for Collisions' on your Rigid Body Solver. Check that box and you should get the results you are looking for. -Ryan Quote Link to comment Share on other sites More sharing options...
br1 Posted October 7, 2009 Author Share Posted October 7, 2009 Hello, Inside your dopnet there is a checkbox for 'Volume Velocity for Collisions' on your Rigid Body Solver. Check that box and you should get the results you are looking for. -Ryan Spent an afternoon on the problem without seeing that magic toggle ! Thanks a lot Ryan ! Quote Link to comment Share on other sites More sharing options...
