The Contest:
Using no more than 42 nodes in Houdini create an image or animation for everyones viewing pleasure.
This contest is similar to the Demo Scene that those hacker types have. In the "Demo Scene" crazy programmers create images and animations using a super tiny program. The contest forces you to be not only artistic but also technical since you have to be very efficient and clever in how create your networks. For some examples of "real" demos from the Demo Scene you can go to www.scene.org. Here are some of the best from the previous year. http://www.scene.org...s.php?year=2004
(Notice how some of them are only 4k.)
A good example of creating a lot of content with very little input can be seen here
http://odforce.net/f...?showtopic=3156
This contest is open to everyone, including SESI employees, (I'm talking to you Wagner). (Well open to everyone but the judges.) Also, using the retail or apprentice version of Houdini is perfectly fine.
Most importantly, the main point of this contest is learning. By having a node limit you are forcing yourself to try new avenues and approaches, and best of all, when the contest is all over you'll get to see everyone else's hackery.
Submission:
Note: You are allowed to have multiple submissions, just as long as the submissions are fairly different from each other. Submitting two hip files where the only difference is a node or two isn't acceptable. But if you have completely different ideas and want to submit each the go for it.
All entries should be zipped and contain the following 3 files.
Hip or Hipnc file-
We will be verifying the hip files in the Production Builds of Houdini (version 7 and 8) and whatever the latest version of Houdini 8 is at the end of the contest.
Final output- (Image/animation/interactivity)
Images should be in tiff/jpeg/png format, animations should be compressed in a semi popular/common codec.
Interactivity is another option. Instead of rendering out a picture/animation you can also set up your Houdini session to do something like particles interacting with the mouse pointer using the Mouse CHOP. A long long time ago back when version 6 of Houdini came out, a interactive Pong clone was made using Objects, POPs and CHOPs. Doing stuff like this is also perfectly ok.
readme.txt-
Inside the readme should be contact info, (email address, or odforce forum handle)
Also directions on how to "reproduce" your final image/animation. (Render mantra1, hit play in the playbar etc)
If your entry is a interactive demo, then make sure you describe exactly how start the demo. ie)
1- Go to Objects
2- Hit Scroll Lock
3- Hit Play.
If are submitting a animation make sure specify which codec you used.
Email submissions to-
houdini-hacker [at] stickylight [dot] com
[I]If your submission is more than 3-4MB, it might be too large for email. In these cases you can upload via ftp. (For ftp access information please send me a PM).
Please post questions to the forums at odforce.
Deadline:
Before December 1st, 2005 GMT. (All of November)
After the deadline all the entries will be posted on odForce for everyone to enjoy (and learn from).
Prizes:
First Place-
One copy of The Magic Of Houdini
One copy of the Gnomon Workshop DVD Houdini 101: Interface and Workflow
Second and Third Place-
Will get to choose either
or
Judging:
Our team of judges (judges TBA) will judge your final images/animation for their artistic quality AND the hip files for their technical merits. When I say technical quality I don't mean you have to use tons of expressions/scripts/etc, it just means we are checking to make sure you followed the rules below.
When Judging the submissions we will be looking for a couple of things:
(Note this isn't meant to be super strict, these are just to give you an idea of what we like to see)
Proceduralism-
This one is the most important. The point of having a limit on the number of nodes you can use is to force you to use proceduralism to create as much content as nothing. Simply modeling a character with a bunch of edit/ poly-extrudes poly-splits sops isn't really procedural. However creating a simple character and the procedurally growing spike, plants, and teapots out of its head using the SOP Solver is procedural. (Keyframing is ok, but keyframing a character walking won't be ranked as high as a character moving procedurally.)
Artistic-
Is your rendering interesting? Visual aesthetic?
Technical Hackery-
You only have 42 nodes. Are you using them wisely? Could you have combined 3 SOPs into one? Technical Hackery doesn't mean obfuscation. It means are you using different tricks to get the most out of you network. Also these are just things we are looking for, but if you don't have tons of "technical hackery" it doesn't mean we won't be impressed.
The "Whoa, how did they do that?" Factor-
Getting us to say, "Damn I didn't know you could do that." is always a good thing.
Good Clever vs Bad Clever-
An example of "good clever" would be using POPs/DOPs to procedural do a lot of your modeling based off a COP network. "Bad clever" would be embedding a 10 meg hip file with 1000s of nodes into an embedded OTL then extracting it, opening it up as a subprocess hscript session, rendering it then reading the result in. Then again, starting up a subprocess hscript session and keeping within the 42 node limit is a good clever. Confusing? Good.
Rules:
*No more than 42 nodes maybe created. All nodes count toward this total, Subnets, ROPs, even the various network OPs (ie chopnet). So when you start out make sure you do a File->New to clear out any of the default stuff. Note, you may not create more than 42 nodes total, in other words, you can't start off with say 42 nodes then during a script create 23 more, then delete the extra nodes when you are done with them.
*Becareful, container nodes also count. (POPNets and CHOPNets for example). So if you aren't using any particles or chops make sure you get rid of /part/popnet1 or /ch/ch1.
*Some of the Object nodes in Houdini have SOPs in them that aren't needed either. Like the Null Object, has a control and point sop that can be deleted.
*VOPs and VOPNets do NOT count toward the 42 nodes used. The reasoning for this is because you can write the VEX Code by hand in a HDA and someone who was good at doing this has a huge advantage over someone using VOPs (since you need to use a lot of VOPs to do simple operations). Remember though, VOPs and VOPNets do not count, however their instances (SHOPs, VEX SOPs, etc) do count.
*No locked OPs (CHOPs/SOPs). Everything must be generated procedurally on the fly.
*No pre-existing external resources. (textures, geo, etc) You are allowed to generate data procedurally from your Houdini session. (Stuff like shadow maps, textures, point clouds etc.)
*One exception to the no "external resources rule" is that you ARE allowed to use an input source to drive/seed your procedural networks. Input is allowed (audio/video) if its uniqueness isn't a factor. In other words, if I supply a different audio file the hip file will generate a different result, but just as cool. Like a character dancing to music, it doesn't matter what the input music is, it will work properly with whatever waveform. If you are using an input source make sure you include a small sample with your submission.
*You must specify how to activate the Hip file to "demo your demo". Ie) hit the Play Button or render the Mantra ROP. The judges will use only one form of activation. (We won't render the mantra1 ROP, then hit play button, then render the mantra2 ROP...if you have render dependencies you can use the Render Dependencies in Houdini 8, but that will cut into the number of nodes you are have available. Be clever and figure out other ways. (Hint Logic CHOP, pre/post-render scripts.)
*You may use OTLs but they must be embedded into your Hip file. You are allowed to source/exread the sections inside an OTL, but you may not reference textures/geo/channels that are in OTLs. Remember even though you are allowed to source scripts inside of OTLs, any opadds that you do count towards the 42 nodes. So be careful.
*Houdini Digitial Assets (HDAs) are allowed, however the HDA counts as a node along with all the nodes inside of it. Forexample, if you use the Color SOP that counts as 9 nodes. The Color Sop is 1, plus the 8 inside that make it.
*When lighting your scene remember to delete the geometry inside your lights/camera. The nodes inside those objects will count.
*Caution: Some Houdini nodes are actually HDAs, use with caution, (Color SOP).
Misc:
If you have any general questions please post in this forum.
If you have any questions that you want to keep private cause they'll "spoil the surprise" then you can send me a PM.
Also, this contest is not affiliated with Side Effects Software Inc. or the authors of the prizes in anyway... (well..I do spam on the sesi forums a lot...but that doesn't count.)
Good luck and have fun.
Edit #1- 11-01-05
Edited grammar. (Thanks ben)
Edit #2- 11-02-05
Added a bit about allowing interactive submissions. (Where you hip file does something based on user input.)
Edit #3- 11-06-05
Added a note about allowing multiple submissions.
Sign In
Register
Help
MultiQuote
