456.py Setting variables with Python
LaidlawFX
I'm trying to use python to parse $HIP and define variables in houdini. Each Variable Project_Code, Sequence, Shot, and Task can be indeterminant length, so I only really know by the / what each value means. Since I can only use set -g in hscript how would I set these variables?
For instance version is based on hipname, but I need to do somethign like:
hou.hscript('set -g PROJECTCODE' = `pythonexprs("hipSplit[1]")` )
Which doesn't work in context.
$HIP = P:\projects\Project_Code\Sequence\Shot\Task\
import hou
path = hou.hscriptExpression('$HIP')
hipSplit = path.rsplit('/')[1:]
## hipSplit example ['projects', 'Project_Code', 'Sequence', 'Shot', 'Task']
## Sets houdini variable $PROJECTCODE
## PROJECTCODE = hipSplit[1]
## hipSplit[1] is Project_Code
etc...
## Sets houdini variable $VERSION
hou.hscript('set -g VERSION = `evals(substr($HIPNAME,0,evals(strlen($HIPNAME)-4)))`')
Thanks
-Ben
Can you just use os.environ?
>>> import os
>>> hip = '/projects/Project_Code/Sequence/Shot/Task/blah.hip'
>>> tokens = hip.split('/')
>>> os.environ['PROJECT'] = tokens[2]
>>> hou.expandString('$PROJECT')
'Project_Code'
It also evaluates properly as a global variable for me.
Cheers,
koen
  • 1 year later...
