Atom's Video Tutorials
Atom
  • 3 weeks later...
  • 1 month later...
I have put together a short video on how to leverage Houdini 16 pyro instancing. Two modes are demonstrated, one from static scatter points and another from particle system impacts.
I got a lot of help on this one from the community on this one. Thank You all very much for answering my endless questions.:D
Edited by Atom
  • 4 months later...
  • 2 months later...
In this video I demo a script that will scan a folder for .OBJ files and create a geometry object for each file it finds on the disk. I further demonstrate how to export those referenced files into the Redshift Proxy file format and construct a simple disk based instancer for fast render times. The script and code I reference in the video are attached in the ZIP file below.
createSubnetOfFileNodes.zip
  • Like 2
  • Thanks 1
  • 3 weeks later...
  • 2 years later...
  • 5 weeks later...
  • 3 weeks later...
I put together a short video on how to make smoke fall into a hole. There is also a setup at the end that shows how to generate a fake @heat field using the VDB Diagnostics node.
  • Like 2
  • Thanks 1
