missile trail simulation/rendering
catchyid
I want to simulate/render a missile smoke trail, I've used initially particles + sprites, but the result was not really satisfactory (see attached). My question here: I want to produce realistic film quality smoke trail, is it possible to do that using particles + sprites or I will just be wasting my time? I am still learning Houdini, but I think simulating smoke physics using particles + expressions/forces won't be possible, also rendering sprites to mimic real smoke is possible but would be challenging. I prefer to use particles+sprites though because I think they will be faster to simulate compared to pyro simulation, specially that the missile is traveling a vast distance and hence the fluid grid will get really big and too slow to simulate!? So in summary, should I keep trying with Particles + Sprites to produce film quality missile smoke trail OR I should switch to Pyro?
Thanks
Edited by catchyid
Here are a couple of example files to check out. One demonstrates copy/instancing of volumes along points. Try out the various switch options.
The other one is really cool in that it demonstrates smoke clustering by instancing volume domains. This is how you keep your volumes from getting really large.
ap_cluster_smoke_on_path_128.hipnc
ap_popnet_missile_trail_1e.hipnc
Edited by Atom
  • Like 4
Thanks guys... I think I must use pyro to get nice simulation/rendering. Thanks Atom for your teapot example, breaking down pyro simulation into multiple container is essential here to avoid having one big container, but I have a question though: would these container move fields between them, i.e. if temperature is rising at the border of one container, would the neighbor container catches that temperature or I have to write some code to move fields across the borders?
Thanks
