Channel Reference?
bretik
Hi I have dumb question.. But I cant figure it out.. :( Im quite new in houdini..
Heres the thing
Im creating MIDI playing piano
I have CHOP_Network, inside i have MIDI_in node...     /obj/pno/CHOP_Network/midiin1
I have channels there... and  I have channel named con_64 which is for sustain pedale
And I have object of pedale ( /obj/PEDALE ) , which i want to rotate in say X by te value of con_64
Im sure its pretty easy.. but... I dont know how... Thanks for any answer...
Hi, I am not sure I understand the question, but just out of curiosity, have you tried right click (on the channel you want to copy) then copy a channel then right click (where you want to paste its value) then choose "paste copied relative reference"...i.e. copying/pasting channel values is just as easy as: copy/paste copied relative reference
Hi, you need to use the "chop" expression instead:  chop("/obj/pno/CHOP_Network/midiin1/con_64")
Here's something that might help you find this in the future.  If you open an hscript text port, (Windows -> hscript textport), and then type:
exhelp -k chop
help -k chop
... you will see all expressions, functions, etc, with the word "chop" in them.
Just "help chop" or "exhelp chop" will give you the help for that exact function if it exists, or if it does not exist, for any function that has "chop" in the name.
