Saving single geo-sop
Follyx
is there a way to save a single geo.sop with a seperate network in it?
i.e. selectin geosop_xyz -> save selected node as... / export... blabla
! except the way via asset
thanks in advance
Edited by Follyx
Just copy the code directly to a new shelf tool. That is where I run it from.
The line you want to change is this one.
lst_node_root = ["/obj","/shop","/out"]
# Change to..
lst_node_root = ["/obj/my_subnet"]
It should make a folder on your desktop called HipAsCode.
Edited by Atom
