Where to change opencl device
Hans Peter
sigh - as was written on your post in the SideFx forum it's most likely that you have a different OpenCL vendor - therefore you need to set that vendor first.
  • 3 weeks later...
Its just not working.
When I type "set HOUDINI_OCL_DEVICENUMBER=1" in the shell it then tells me that the second card is used for opencl. But when performance monitoring during a sim still the other card is used.
When pasting "HOUDINI_OCL_DEVICENUMBER=1" in the houdini.env file nothing at all happens. When putting this in the system variables nothing happens to.
Edited by Heraklit
  • 3 weeks later...
Well, much more accessable VRAM due to not being responsible for a display. So I don't know how much of that 11 GB you effectively can use when the card runs a lot of other things + the viewport..but probably around 6 GB are REALLY free? The titan gives me much more space.
Well, the card speeds up unter pressure - like the cpu or whatever. It just doesn't with opencl. Its a titan x maxwell hydro copper. Standard overclocking from the manufacture is @ around 1375 mhz. I overlocked it to even 1500 MHZ. Houdini's opencl is pushing the card to only around 1100 MHZ. Same problem with the 1080 ti. Its running at a max of 1400 where during gpu rendering or gaming @ nearly 2000.
