(novice) ADD points to geometry
ok, so Scatter SOP CONVERTS your geometry to points, but I need to ADD points to existing geometry.
The problem is that I'm trying to use the Stitch Cloth shelf tool and it is asking for some constraint points on my geometry.
Tried merging after I Scatter but don't think its doing what I want.
Edited by art3mis
you can just use the same scatter to add more points to your geo. Im not sure if I understand completely your question. It might be helpful to upload your .hip
Edited by Sepu
The source geometry is an imported .obj file. Could that be part of the problem? See attached. Notice that no points are visible in my Scene view with Scatter node OFF even though I have Show Points activated.
Edited by art3mis
