Welcome to od|forum
Register now to gain access to all of our features. Once registered and logged in, you will be able to contribute to this site by submitting your own content or replying to existing content. You'll be able to customize your profile, receive reputation points as a reward for submitting content, while also communicating with other members via your own private inbox, plus much more! This message will be removed once you have signed in.
ejr32123
Mantra Render to Disk Stops Randomly
Hey,
I am rendering to disk a 400 frame ocean simulation. The ocean mesh and foam particles are cached out. I hit render to disk, and it will randomly stop rendering. No error. It even still has render dialog up. However, the file size on frame it is "rendering" currently doesn't change and there is no mantra checkpoint. It just stays sits and does nothing. I have to keep starting the job again and again. Once I start it again it keeps rendering till it randomly stops. What could cause that? This has happened to me before on other  simulations.
Thanks.
Share this post
Link to post
First thing to check is by turning up the verbosity and using hbatch to render. That both adds render info and takes away the GUI part.
1 person likes this
Share this post
Link to post
Thanks mate, I will look into this.
Share this post
Link to post
Sometimes you can have a read error loading the cache, you can try selecting "no geometry" instead of "report error" at "missing frame". That way it will be rendering your frame without your geo, so you must pay attention later.
1 person likes this
Share this post
Link to post
Render in the Backgrond seemed to mostly fix this issue for me.  It still failed once, though, and now I just render in smaller chunks--four 100-frame sessions, for example.
Share this post
Link to post
I never saw this before setting before. I believe this was exactly what I needed. thanks. I tried it, and it rendered the frame with out the geo. Must be because the network location to where the cache is located is causing trouble.
Edited by ejr32123
1 person likes this
Share this post
Link to post
Can you send that in as RFE to SideFX. It seems that a better failsafe or error message would help many people.
1 person likes this
Share this post
Link to post
Good idea the RFE :)
Another option is to manage that with thinkbox deadline, for one (and maybe two) pc is free. And you can also manage dependencies and so on ... it's really useful for me
Edited by merlino
Share this post
Link to post
I just noticed I am also getting another error. It says error writing data to image device then it stays stuck on the same frame and I have to send it again. What would cause this? Seems weird considering if I send it again it works. Also, why wouldn't it either try again or move to next frame?
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
