jakigui
ocean fluid extend issue
Hard to see. Can I see the hip file?
Try to increase voxel resolution for "particle fluid surface" - default 0.75 scale down to 0.5 and so on. See if u notice some improvement.
Good luck!
Share this post
Link to post
I am still new to FLIP, but I always find these pumps/creases! the only workaround I do is to expand the ocean beyond what camera sees! Not a solution, but I would be very interested to know if there is a way to get rid of it...
Share this post
Link to post
I think that bump/crease at the boundary is from "water level" parameter. Yours is set at -0.4, so the extended part will have its height at -0.4 in Y-Axis. Water Level in flattank_initial comes in as "0", assuming that you didn't change that, the value of -0.4 in your particle fluid surface is lower than this value, thus makes the whole extended part lower than your main area. Try adjusting that to have the same height as the main area, and maybe that will work.
Best,
Phiphat
Share this post
Link to post
Best,
Phiphat
Thanks. I checked water level is same as the main area.
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
