Color value for each polygon
CinnamonMetal
Yep, tons of errors in that. You can only return from a function, which you have not declared.
Here is my guess of what you might want. But be aware, the code will fail if there is no Cd attribute on the incoming primitives. So you may need to use hasAttribute before you attempt to retrieve the value.
node = hou.pwd()
geo = node.geometry()
for thePrim in geo.prims():
    primColor = thePrim.floatListAttribValue("Cd")
Edited by Atom
