vector flows along edge of primitive
CinnamonMetal
How do you add a vector for a point that follows the edge of a primitive ? Suppose a point is on an edge, now I want a vector to point along the edge.  If I use set() I'm simply setting a vector for an axis, which I don't want.
Edited by CinnamonMetal
  • 2 weeks later...
You can use the neighbours() function.
int pt = 0;
vector pt_pos = point(0, "P", pt);
int neighbours[] = neighbours(0, pt);
vector neighbour_pos = point(0, "P", neighbours[0]);
vector along_edge = normalize(neighbour_pos - pt_pos);
  • 2 weeks later...
int vp3 = vertexpoint(0,@vrtList[1]);
int neighbours = (0,vp3);
v@alongEdge = vp1 - vp3;
The attribute vrtList is an array containing the primitive vertices.
When displaying the attribute alongEdge the vector doesn't flow along the vertices, in this case; vertices three to vertices one. Instead the vector is directed out from the third vertices, as it's not following the edge of the primitive ?
I hope this illustration helps.  The red points are vertices; the yellow arrow is the vector that flows along the edge of the primitive which is what I want to achieve between vertices.
