Underwater Caustic Effect
kingsoz
ellooooooooooo
right, i know how to do this in max, so i know what i want i just don't know how to do this in houdini...
basically i think i need an animated noise map thingy which gets projected through one of my lights to fakely simulate underwwater caustics. do i have to use VEX builder to create a surface or light shader?? if so what nodes do i use??
thanksss
King Soz
What do you need? Rays that project on the floor? Rays that just penetrate the a short way from the surface and twinkle? Volumetric shadows?
Can you give us reference images?
This slow-but-realistic way is to render maps out of COPs (thresholded turbulent noise is good for this) and use the maps in a VEX Lit Fog shader, but if you can cheat depending on your scene needs, do it.
What about crating an animated texture with the caustic pattern, you cn do this using COPs for example, there is a tutorial for houdini 6 in the sidefx site about to do this.
And then use this textures as projectors for a volumetric light.
